Nintendo Switch | |
Manufacturer | Nintendo |
Code name | HAC-001 and HAC-001(-01) |
Release date | March 3, 2017 |
Device type | Game Console |
Type | Difficulty | |
Diagnosing Power Draws on Nintendo Switch | Troubleshooting/Diagnostics | 2. Medium |
Nintendo Switch CPU capacitors | Circuit | 1. Easy |
Nintendo Switch No Fan Spin Voltage Injection Method | Method | 2. Medium |
Nintendo Switch Not Charging | Troubleshooting/Diagnostics | 2. Medium |
Nintendo Switch
Nintendo Switch Fan Pinout
CPU capacitor next to the SOT-323 IC near MAX17050
M92T36 CPU Capacitor
