Nintendo Switch Only charges from 5v cable Repair | |
Device | Nintendo Switch |
Affects part(s) | Charging circuit |
Type | Soldering |
Repair of an issue where the Switch only charges from 5v cable
- Only charges from 5v cable
The culprit is M92T36. Replace it.
