| Type | Component |
| Device(s) | Resistors |
What is a Resistor?
Voltage divider
A voltage divider is an electrical circuit that divides a higher input voltage into a lower output voltage using two or more resistors in series.
The output voltage of a resistive divider is determined by the ratio of the resistance values in the circuit like so:
When the circuit is loaded, it is equivalent to an ideal voltage source supplying the unloaded voltage, with a series resistor of a value equal to R1 and R2 in parallel.
Uses:
- Reference Voltage: Voltage dividers can be used to create stable reference voltages for sensor calibration, analog signal processing, and feedback in voltage converters; provided they are powered from a stable voltage source, as any deviations in the source voltage will likewise appear in the scaled down output.
- Voltage Monitoring: In some battery-powered devices, voltage dividers are used to monitor the battery voltage to determine its state of charge. This is a similar application to the aforementioned voltage scaling for measurements.
- Volume control in analog audio: for this, a potentiometer is used, to have an adjustable ratio in the divider and thus making the volume user-adjustable.
- Et Cetera.
Resistor sensors
Pull-up / Pull-down
Current measurement
Resistor Packages and Value Codes
Axial Through-Hole Resistor
Surface Mount Device (SMD)
These resistors come in different sizes but are usually small in size and have no wire leads, instead their metallized ends get soldered directly to pads on a circuit board.
Appearance wise, they are small rectangular and thin wafers, black on top with a white ceramic substrate underneath, and a three or four digit numerical code denoting the value, where the last digit is the multiplier or "number of zeroes" (for example, 221 on a resistor means 220 ohms).
Another notation has the value written as a number with decimals, where the decimal point is replaced with a letter that represents the multiplier (R for 1, K for 1000, M for 100000), for example, "4k7" denotes a 4700 Ohm resistor. Sometimes the letter will be at the beginning or the end, indicating there would be a zero on the unused side. For example, K33 for a 330 Ohm resistor, or 10R for a 10 Ohm one.
This notation is also occasionally used in power resistors of the through-hole axial and ceramic types.
Wire Wound Resistor
One of the oldest types of resistors and still widely used for power applications. They are made of a length of metal wire coiled around a rigid insulating core for support or potted in a porcelain shell with cement.
The wire is usually Nichrome for its high temperature resistance, and the cores are usually made of some form of ceramic, mica or rarely glass for the same reason. Some antique resistors contained asbestos in the core.
Of the ceramic core types, most have the core covered in glaze, encasing the windings. Sometimes the glaze would leave a strip of uncoated windings along the length of the resistor, in order for a clamp to be attached and make contact at a desirable location, making a tapped resistor. The core itself is hollow to allow a bolt to pass through for fastening.
Some other examples leave the windings uncovered, usually in older high power resistors and rheostats.
Their most common use is as power resistors, and as heating elements. Some high precision resistors for instruments are also wire wound, sometimes with two different thicknesses of wire to trim the value to spec. These sometimes lack the construction meant to withstand high temperatures.
Because of their construction, they can have substantial parasitic inductance, making them unsuitable for high frequency applications. They can also introduce RF noise to a circuit, acting as loop antennas.
Metal Film Resistor
Made by depositing a microscopically thin layer of metal on a ceramic substrate, and sometimes with a spiral pattern etched to make something akin to a wirewound resistor. This can give them similar issues with inductance but to a much lesser degree.
Carbon Composite Resistors
They were the most common in electronics around the middle of the 20th century, and are made of a slug of a graphite-infused composite material, with leads at each end and encased in bakelite. Many have drifted susbtantially in value over the decades.
They most often use the colored bands code, with some examples having only 3 bands, lacking the tolerance band.
One of their advantages was having very low parasitic inductance.
Variable resistors
Potentiometers
Thermistors
Varistors
A varistor, despite often being considered a type of resistor, is actually a semiconductor device with a behavior similar to a pair of zener diodes wired in anti-series (in series but in opposite directions). This effectively means that the varistor is non conductive in either direction up to a specific threshold voltage (positive or negative), where it suddenly starts conducing and clamps down the voltage to this limit.
They are used to protect electrical circuits and devices from voltage spikes or transient overvoltage conditions. Varistors are also known as voltage-dependent resistors (VDRs) because their electrical resistance changes with the applied voltage. They are commonly used in various electronic and electrical systems to absorb and dissipate excess voltage, preventing damage to sensitive components.
Modern varistors, called Metal Oxide Varistors, are made by sintering oxidized metal granules into pellets in a controlled manner, the metal oxide forms effectively a mass of randomly oriented, microscopic diodes which end up forming series chains by mere chance; hence the non polarized behavior with a diode-like threshold voltage.
Historical varistors were made by connecting two copper oxide or selenium rectifiers in antiparallel, and were mostly used to protect telephone lines and receivers.
Photoresistors
Also known as Light Dependent Resistors (LDRs), these exhibit changes in resistance based on the intensity of light falling on them. They are used in light-sensitive applications. They are usually small, though large ones are used in applications such as light-sensing streetlight switches, where they drive a thermal relay dirctly.
Testing a Resistor
Replacement Considerations
