Nintendo Switch Draws 0.4a - 0.6a from charger but does not turn on Repair
Device Nintendo Switch
Affects part(s) EMMC
Difficulty ◉◉◌◌ Medium
Type Part replacement
Fixing a problem where the Switch is drawing 0.4a - 0.6a from charger but does not turn on
  • Draws 0.4a - 0.6a from charger
  • Does not turn on
Do not forget to plugin the EMMC. Otherwise you may have an issue with P13USB audio/video IC. Full video here
