| Nintendo Switch Console only charges from one side of the USB-C port Repair | |
| Device | Nintendo Switch |
Fixing an issue with the Nintendo Switch where the console only charges from one side of the USB-C port
- Console only charges from one side of the USB-C port
- Potential issue with port, M92T36, P13USB, diode packs. Full video here
- Check port for damage or incorrect installation. If no damage and port appears fine, change M92T36
