Nintendo Switch Console appears to have no power, but makes sounds when touch screen is tapped Repair
Nintendo Switch Console appears to have no power, but makes sounds when touch screen is tapped Repair | |
Device | Nintendo Switch |
Affects part(s) | LCD, Rippon connector |
Needs equipment | Screwdriver set, tweezers |
Difficulty | ◉◉◌◌ Medium |
Type | Part replacement, Cleaning |
- Console appears to have no power, but makes sounds when touch screen is tapped
- Ensure the LCD and backlight are not damaged. Check for liquid damage around the backlight ribbon or damage to the LCD or LCD connector
- Check for shorts or damage around the LCD Driver to the left of the LCD Connector (83160722)
