Nintendo Switch restarts when you put it into standby Repair | |
Device | Nintendo Switch |
Type | Soldering |
Fixing a problem where the Switch restarts when you put it into standby
- Switch restarts when you put it into standby
Check the mosfets above the usb type c port, click here to learn more about MOSFETs and how to check them. Replace them if faulty.
