Nintendo Switch CC1/CC2 lines are shorted to ground after replacing the M92T36 IC and connecting the Switch charger Repair
Nintendo Switch CC1/CC2 lines are shorted to ground after replacing the M92T36 IC and connecting the Switch charger Repair | |
Device | Nintendo Switch |
Type | Soldering |
CC1/CC2 lines measure less than 10 ohms to GND after replacing the M92T36 IC and connecting the Switch charger
- Sub 10 Ohms to GND on the CC1/CC2 lines
Replace the 3v3 buck converter IC (next to the Audio IC) Source: https://gbatemp.net/threads/fried-multiple-m92t36.572667/
