| Nintendo Switch False Charging Repair | |
| Device | Nintendo Switch |
| Affects part(s) | Charging circuit |
False Charging (recognizes charger on both sides and gives charging symbol but decreases %. Will show charging symbol but drains power (back-feeding)
- Says that it is charging but actually draining the battery
Check M92T36, P13USB and BQ24193. Replace as necessary.
