Nintendo Switch Error Code 2134-0501 Repair | |
Device | Nintendo Switch |
Type | Soldering |
Fixing a problem with a Nintendo Switch in the form of error code 2134-0501
- Error Code 2134-0501
In most scenario, this 21xx-xxxx error code is referred to bootup self-check failure, and by most case due to M92T36 PD control ic, replace it with known good one.
- Check voltages around MAX77620 (esp 1v05 rail) Reference, if voltages good replace MAX17050 fuel gauge
