| Nintendo Switch No touch screen after Game cartridge replacement Repair | |
| Device | Nintendo Switch |
| Affects part(s) | Touch Screen |
| Needs equipment | None |
| Type | Software |
Fixing an issue where touch screen is not working after Game cartridge replacement on a Nintendo Switch
- No touch screen after Game cartridge replacement
- If your console can be hacked, boot into Hekate and try the touch screen calibration menu. Once done, your touch screen should work fine on the original firmware.
- If your console is patched, try another cartridge reader version (CV, DN or DM). Also, you could try to calibrate the cartridge board using a hacked Switch then put it back on the original console.
