| Nintendo Switch | |
| Manufacturer | Nintendo |
| Code name | HAC-001 and HAC-001(-01) |
| Release date | March 3, 2017 |
| Diagnosing Power Draws on Nintendo Switch | Troubleshooting/Diagnostics | 2. Medium |
| Nintendo Switch CPU capacitors | Circuit | 1. Easy |
| Nintendo Switch No Fan Spin Voltage Injection Method | Method | 2. Medium |
| Nintendo Switch Not Charging | Troubleshooting/Diagnostics | 2. Medium |
Nintendo Switch
Nintendo Switch Fan Pinout
