| Nintendo Switch | |
| Manufacturer | [[:Category:|]] |
| Code name | |
| Release date | |
| Device type | |
External Sources
Guides to repair in hard cases: https://www.retrosix.wiki/board-scans-nintendo-switch
- Diagnosing Power Draws on Nintendo Switch
- Nintendo Switch Blue screen of death Repair
- Nintendo Switch CC1/CC2 lines are shorted to ground after replacing the M92T36 IC and connecting the Switch charger Repair
- Nintendo Switch CPU capacitors
- Nintendo Switch Console appears to have no power, but makes sounds when touch screen is tapped Repair
- Nintendo Switch Console only charges from one side of the USB-C port Repair
- Nintendo Switch Console turns on shows first logo and goes black Repair
- Nintendo Switch Console works fine, but there are no WiFi networks being detected Repair
- Nintendo Switch Doesn't turn on after port replacement Repair
- Nintendo Switch Draws 0.00a Repair
- Nintendo Switch Draws 0.4a - 0.6a from charger but does not turn on Repair
- Nintendo Switch Error Code 2002-2663 Game Cartridge Error
- Nintendo Switch Error Code 2134-0501 Repair
- Nintendo Switch Error Code 2162-0002 Repair
- Nintendo Switch Error Code: 2101-0001 Repair
- Nintendo Switch Error code 2002-3538 Repair
- Nintendo Switch Error code 2153-0321 Repair
- Nintendo Switch Error codes: 2107-0445 and 2110-1115 Repair
- Nintendo Switch False Charging Repair
- Nintendo Switch Game cartridge not reading Repair
- Nintendo Switch Joycon only works wirelessly and still charges Repair
- Nintendo Switch Joycons don't charge on both sides and fan does not spin Repair
- Nintendo Switch Joycons not charging or connecting Repair
- Nintendo Switch No Backlight
- Nintendo Switch No Fan Spin Voltage Injection Method
- Nintendo Switch No fan spin and not charging joycons Repair
- Nintendo Switch No touch screen after Game cartridge replacement Repair
- Nintendo Switch Not Charging
- Nintendo Switch Not turning on at all Repair
- Nintendo Switch Not turning on, draws 0.2A @ 15V from charger and slowly drops Repair
- Nintendo Switch Not turning on, draws 200mA at 15V Repair
- Nintendo Switch Only charges from 5v cable Repair
- Nintendo Switch Orange Screen On Bootup Repair
- Nintendo Switch Overheating And Joycon Issues Repair
- Nintendo Switch Video Output Issues: No Video or HDMI Output
- Nintendo Switch When both Joycons are docked A Joycon disconnects Repair
- Nintendo Switch restarts when you put it into standby Repair
