Nintendo Switch
Revision as of 13:27, 15 August 2025 by Tiago199988 (talk | contribs) (added link to boardview)
Nintendo Switch
Manufacturer Nintendo
Code name HAC-001 and HAC-001(-01)
Release date March 3, 2017
Device type Game Console
Diagnosing Power Draws on Nintendo SwitchTroubleshooting/Diagnostics2. Medium
Nintendo Switch CPU capacitorsCircuit1. Easy
Nintendo Switch No Fan Spin Voltage Injection MethodMethod2. Medium
Nintendo Switch Not ChargingTroubleshooting/Diagnostics2. Medium
Nintendo Switch Blue screen of death RepairMain Logic BoardBGA
Soldering
4. Specialist
Nintendo Switch CC1/CC2 lines are shorted to ground after replacing the M92T36 IC and connecting the Switch charger RepairMain Logic BoardSoldering3. Hard
Nintendo Switch Console appears to have no power, but makes sounds when touch screen is tapped RepairLCD
Rippon connector
Part replacement
Cleaning
2. Medium
Nintendo Switch Console only charges from one side of the USB-C port RepairMain Logic BoardSoldering3. Hard
Nintendo Switch Console turns on shows first logo and goes black RepairMain Logic Board
Battery
Soldering
Part replacement
3. Hard
Nintendo Switch Console works fine, but there are no WiFi networks being detected RepairMain Logic BoardSoldering3. Hard
Nintendo Switch Doesn't turn on after port replacement RepairMain Logic BoardSoldering3. Hard
Nintendo Switch Draws 0.00a RepairWhole boardSoldering3. Hard
Nintendo Switch Draws 0.4a - 0.6a from charger but does not turn on RepairEMMCPart replacement2. Medium
Nintendo Switch Error Code 2002-2663 Game Cartridge ErrorGame CartridgeSoldering3. Hard
Nintendo Switch Error Code 2134-0501 RepairMain Logic BoardSoldering3. Hard
Nintendo Switch Error Code 2162-0002 RepairMain Logic BoardSoldering3. Hard
Nintendo Switch Error Code: 2101-0001 RepairMain Logic BoardSoldering
Part replacement
3. Hard
Nintendo Switch Error code 2002-3538 RepairEMMCSoldering
Software
3. Hard
Nintendo Switch Error code 2153-0321 RepairMain Logic BoardSoldering3. Hard
Nintendo Switch Error codes: 2107-0445 and 2110-1115 RepairWIFI / Bluetooth chipSoldering
Part replacement
3. Hard
Nintendo Switch False Charging RepairCharging circuitSoldering3. Hard
Nintendo Switch Game cartridge not reading RepairMain Logic BoardPart replacement
Cleaning
3. Hard
Nintendo Switch Joycon only works wirelessly and still charges RepairMain Logic BoardPart replacement2. Medium
Nintendo Switch Joycons don't charge on both sides and fan does not spin RepairMain Logic BoardSoldering3. Hard
Nintendo Switch Joycons not charging or connecting RepairJoyConsSoldering3. Hard
Nintendo Switch No BacklightLCD
Motherboard
Soldering
Part replacement
3. Hard
Nintendo Switch No fan spin and not charging joycons RepairMain Logic BoardSoldering3. Hard
Nintendo Switch No touch screen after Game cartridge replacement RepairTouch ScreenSoftware1. Easy
Nintendo Switch Not turning on at all RepairMain Logic BoardSoldering3. Hard
Nintendo Switch Not turning on, draws 0.2A @ 15V from charger and slowly drops RepairMain Logic BoardBGA
Soldering
4. Specialist
Nintendo Switch Not turning on, draws 200mA at 15V RepairMain Logic BoardSoldering3. Hard
Nintendo Switch Only charges from 5v cable RepairCharging circuitSoldering3. Hard
Nintendo Switch Orange Screen On Bootup RepairMain Logic BoardSoldering3. Hard
Nintendo Switch Overheating And Joycon Issues RepairMain Logic BoardSoldering3. Hard
Nintendo Switch Video Output Issues: No Video or HDMI OutputMotherboardSoldering3. Hard
Nintendo Switch When both Joycons are docked A Joycon disconnects RepairJoyConsPart replacement2. Medium
Nintendo Switch restarts when you put it into standby RepairMain Logic BoardSoldering3. Hard
Nintendo Switch Boardview use FlexBV to open: https://www.sendspace.com/filegroup/%2BXRTDGT2a0vow%2BNHFEIORLv5UBi8QVaI
Nintendo Switch Parts List
Parts Description Source
M92T36 USB-C Power Management IC Aliexpress
PI3USB30532ZLEX Audio/Video IC Mouser
BQ24193 Battery Charging Management IC Aliexpress
MAX17050 Fuel guage (battery level detection) IC Aliexpress
BCM4356XKUBG WiFi IC Aliexpress
MAX77620AEWJ+T Big PMIC (Side-B) Aliexpress
MAX77621AEWI+T Little PMIC (CPU & Ram) Aliexpress
P15123CT USB-C Protection Fuse DigiKey
TPD2E1B06DRLR Diode Packs Digikey
MCZ1210DH900L2TA0G Large EMI Filters Digikey
MCZ0605AH900SDT000 Small EMI Filters Digikey
Molex 503300-5310 LCD FPC for Nintendo Switch (NOT LITE) Digikey/Mouser
DX07BN24JA2R1300 USB-C Connector Mouser
