Which iPhones Will Boot With Top Board Only | |
Device(s) | IPhone X, IPhone XS, IPhone XS Max, IPhone 11, IPhone 11 Pro, IPhone 11 Pro Max, IPhone 12, IPhone 12 Mini, IPhone 12 Pro, IPhone 12 Pro Max, IPhone 13, IPhone 13 Mini, IPhone 13 Pro, IPhone 13 Pro Max, IPhone 14, IPhone 14 Plus, IPhone 14 Pro, IPhone 14 Pro Max, IPhone 15, IPhone 15 Plus, IPhone 15 Pro, IPhone 15 Pro Max |
Difficulty | ◉◌◌◌ Easy |
Summary
When troubleshooting a board issue on a 2 layer sandwich board, sometimes it's a good idea to isolate the board to the bare minimum.
That includes, splitting the sandwich & test with the top board only.
When testing with top board only or with a non-original bottom board, you may get a white screen that says "Swipe To Recover". This just means it needs to "reconfigure itself" with the new NFC chip it has detected. All you have to do is type in the correct pin code twice & let it do it things. It will have a loading bard with a "attempting data recovery" message.
If it goes back to the "Swipe To Recover" message, then it means the pin code was incorrect or the phone restarted.
Top Board Only Useful Info
Top Board Only Sandwich Boards | Will boot? | Touch? | Restart Issues? | Temp Warning Issue? | Notes |
iPhone X (Intel) | No | No | N/A | N/A |
iPhone X (Qualcomm) | Yes | No | No | No |
iPhone XS, XS Max | Yes | No | No | No |
iPhone 11 | Yes | Yes | Yes | No |
iPhone 11 Pro, 11 Pro Max | Yes | Yes | No | No |
iPhone 12, 12 Pro, 12 Mini | Yes | Yes | No | No |
iPhone 12 Pro Max | Yes | Yes | No | Yes |
iPhone 13 Mini | Yes | Yes | Yes | No |
iPhone 13, 13 Pro, 13 Pro Max | Yes | Yes | No | No |
iPhone 14, 14 Plus | No | N/A | N/A | N/A |
iPhone 14 Pro, 14 Pro Max | Yes | Yes | Yes | No |
iPhone 15, 15 Plus | No | N/A | N/A | N/A |
iPhone 15 Pro, 15 Pro Max | Yes | Yes | Yes | No | TBD... |
