IPhone 12
IPhone 12
Manufacturer Apple
Code name A2172, A2402, A2403, A2404
Release date 2020-10-23
Device type Phone
WiFi IC
4. Specialist
iPhone 12 Self Repair Store
Repair Manual ID: RBQEVH
Schematics for iPhone 12: https://www.sendspace.com/file/zaxilx
