IPhone 11 Pro
IPhone 11 Pro
Manufacturer Apple
Code name
Release date September 20, 2019
Device type Phone
How To Fix an iPhone 11 Pro That Randomly RestartsMain Logic BoardPart replacement1. Easy
NAND
Soldering4. Specialist
How to fix iPhone 11 stuck in recovery mode with failed at Rose Error -1Main Logic BoardSoldering4. Specialist
IPhone 11 Pro and iPhone 11 Pro Max Not Powering on, 2a or Higher Power Draw After Prompt to BootMotherboardSoldering3. Hard
Schematics for iPhone 11 Pro: https://www.sendspace.com/file/nqi4cz
