How to fix iPhone 11 stuck in recovery mode with failed at Rose Error -1
Device iPhone 11, iPhone 11 Pro, iPhone 11 Pro Max
Needs equipment Soldering Iron, Hot Air Station, Reballing Stencil
Difficulty ◉◉◉◉ Specialist
Problem Description
An iPhone 11 or 11 Pro is stuck in recovery mode and fails to restore when flashing with 3uTools. The flash process typically reaches 90% and then fails with Error Code -1.
This is most often caused by the Rose IC not being detected. On the iPhone 11 (non-Pro), this can happen because of:
  • A bad Rose IC
  • Cracked solder joints or separation between the top and bottom logic board layers after a drop, which interrupts Rose IC communication
On iPhone 11 Pro / Pro Max models, the Rose IC sits on the top board, so interposer issues are not usually responsible — the fault is almost always with the IC itself.
iPhone 11-11 Pro Max Flashing Error (ROSE IC)
  • Device is permanently in Recovery Mode.
  • Flashing fails at ~90% with error (-1) in 3uTools.
  • Unplugging all flexes and trying to flash doesn't fix the issue.
iPhone 11 Rose IC location
  1. Visual Inspection
    • Open the device and check for signs of water damage, board warping, or physical cracks.
    • Look closely for separation between board layers.
  2. Restore Attempt
    • Attempt a full flash using 3uTools.
    • Confirm the process fails at 90% with error -1.
  3. iSocket Test (Non-Pro Models)
    • Separate the logic board layers carefully.
    • Place both layers in an iSocket/test fixture and attempt flashing again.
    • If flash succeeds: The fault is with the interposer/middle-layer connection — reball the board layers and rejoin them.
    • If flash fails: Move on to Rose IC diagnosis and replacement.
  4. Skip iSocket Test on Pro Models
    • Since Rose IC is on the top board, interposer issues are not the cause.
iPhone 11 Pro & Pro Max Rose IC location
Solution 1: Reball the Middle Layer (iPhone 11)
  • Clean and reball all interposer pads on top and bottom board layers.
  • Rejoin board with a preheater and proper alignment jig.
  • Test flash again — in many cases this restores proper Rose IC communication.
Solution 2: Replace or Reball Rose IC
  • Locate Rose IC on the bottom board (11) or top board (11 Pro/Pro Max).
  • Remove and replace with donor chip.
  • Clean the pads, reflow, and reassemble.
Solution 3: Final Flash & Verification
  • Reassemble iPhone partially and attempt a full restore.
  • If successful, phone should boot normally and pass activation.
  • Perform a full functional check (Wi-Fi, LTE, Face ID, etc.) before final assembly.
