| IPhone 14 Pro | |
| Manufacturer | Apple |
| Code name | |
| Release date | 2022-09-22 |
| Device type | Phone |
| How To Fix an iPhone 14 Pro That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
iPhone 14 Pro and Pro Max share the same top board, with only 1 resistor being different. This image shows where the Board ID resistor is located & what value it must be so it can be use for both iPhone 14 Pro and iPhone 14 Pro Max. iPhone 14 Pro: 1M Ohm. 14 Pro Max: 1K Ohm
Batery fpc
Charging fpc
Display fpc
Big camera fpc
Compass fpc
Wireless charger and power button fpc
Antenna fpc
Selfie fpc
Flash fpc
Upper antenna fpc
Dot matrix fpc
Radar fpc
Camera fpc
Lower antenna fpc
iPhone 14 Pro Self Repair Store
Repair Manual ID: CBLXRW
