| IPhone 12 Mini | |
| Manufacturer | Apple |
| Code name | |
| Release date | 2020-10-23 |
| Device type | Phone |
| How To Fix an iPhone 12 Pro that is not charging and touch not working | Main Logic Board | Soldering | 4. Specialist |
| How To Fix an iPhone 12 That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
| IPhone 12 Screen Stays Dim and Can't Increase Brightness Repair | Motherboard | Part replacement | 1. Easy |
| IPhone 12 Stuck on the Apple Logo Error 4013 Repair | Motherboard | Part replacement | 1. Easy |
iPhone 12 Mini Self Repair Store
Repair Manual ID: VXUZTC
