| IPhone 13 Mini | |
| Manufacturer | Apple |
| Code name | |
| Release date | |
| Device type | Phone |
| How To Fix an iPhone 13 That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
iPhone 13 Mini Self Repair Store
Repair Manual ID: PMCEGT
