| IPhone 14 Pro Max | |
| Manufacturer | Apple |
| Code name | A2894, A2651, A2893, A2895 |
| Release date | 2022-09-16 |
| Device type | Phone |
| How To Fix an iPhone 14 Pro That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
| IPhone 14 Pro Max – No Modem Firmware After RF Layer Swap | Motherboard | Soldering | 3. Hard |
iPhone 14 Pro and Pro Max share the same top board, with only 1 resistor being different. This image shows where the Board ID resistor is located & what value it must be so it can be use for both iPhone 14 Pro and iPhone 14 Pro Max.
iPhone 14 Pro Max Charging Port USB C Readings
Apple Self Repair Store
Repair Manual ID: XGTPKL
