IPhone 12 Pro
IPhone 12 Pro
Manufacturer Apple
Code name
Release date 2020-10-23
Device type Phone
LiDar Sensor
3. Hard
WiFi IC
4. Specialist
iPhone 12 Pro Self Repair Store
Repair Manual ID: FWRUJK
Schematics for iPhone 12 Pro: https://www.sendspace.com/file/zaxilx
