IPhone 14
Revision as of 20:23, 30 June 2025 by Tiago199988 (talk | contribs) (Added device pictures)
IPhone 14
Manufacturer Apple
Code name
Release date September 7, 2022,
Device type Phone
How To Fix an iPhone 14 That Randomly RestartsMain Logic BoardPart replacement1. Easy
How To Fix an iPhone 14 that is shows temperature warning and does not chargeMain Logic BoardSoldering4. Specialist
How To Fix iPhone 14 Not Charging due to open i2c line at battery connectorMain Logic BoardSoldering3. Hard
How To Repair an iPhone 14 Bootlooping due to IR CameraFront Camera
Main Logic Board
2. Medium
How To Turn On iPhone 14 to 16 Plus lower layerLogic BoardSoldering4. Specialist
How to fix iPhone 14 Error 9 with failed RoseMain Logic BoardSoldering4. Specialist
WiFi IC
4. Specialist
iPhone 14 Self Repair Store
Repair Manual ID: LBWDCA
https://support.apple.com/en-us/100308
