How To Fix an iPhone 14 That Randomly Restarts | |
Device | iPhone 14, iPhone 14 Plus |
Difficulty | ◉◌◌◌ Easy |
Type | Part replacement |
There are many reasons that could cause an iPhone 14 and iPhone 14 Plus to randomly restart every few minutes.
For the iPhone 14 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
If certain parts are unplugged, you may also face restarting problems.
The most common for iPhone 14 series are:
- Back Glass/Wireless Charging Flex- This is the flex that is attached to the Back Glass. It can damaged during a drop or screen replacement
- Proximity Flex -This is the flex that is attached to the screen. It can easily be liquid damaged or torn during a screen replacement.
- After a hard drop, the iPhone will restart every 3 minutes.
If you see:
- 0x400000 - it's the Wireless Charging Flex (Back Glass)
- Make sure it's plugged in & the flex is not torn
- Check that there's no liquid damaged, or that it's defective
- Could be a sandwich issue
- 0x100000 - it's the Charging Port Flex
- 0x500000 - Check the taptic engine as well as the charging port flex
- 0x200000 - it's the Proximity Flex Cable
- 0x500000 - it's a communication problem with the battery
- the battery has a communication issue while charging
- restarts every 3min30sec
- test with another battery
- check diode values on battery connector on the motherboard
- 0x600000 - it's wireless Charging flex + proximity Flex Cable
- check with original known good flex
- both must be connected to the motherboard
When troubleshooting these issues, make sure the flexes listed above are all plugged in. You cannot test for restart problems by unplugging the flex cables.
It is also a good idea to keep known good parts on your bench, for testing only.
There are reports of even NEW flexes being bad. So you must keep known good flexes on hand at all times, so you don't waste your time troubleshooting with possibly bad flexes.
Always make sure to replace the appropriate flex with an OEM or Premium parts. Don't use aftermarket parts.
In scenarios where you have the appropriate flexes plugged in (listed above), but it still restarts, then you either have:
- Bad or damaged flex
