IPhone 14 Pro Max
IPhone 14 Pro Max
Manufacturer Apple
Code name A2894, A2651, A2893, A2895
Release date 2022-09-16
Device type Phone
How To Fix an iPhone 14 Pro That Randomly RestartsMain Logic BoardPart replacement1. Easy
LiDar Sensor
3. Hard
WiFi IC
4. Specialist
IPhone 14 Pro Max – No Modem Firmware After RF Layer SwapMotherboardSoldering3. Hard
iPhone 14 Pro Max Charging Port Diode Readings
Apple Self Repair Store
Repair Manual ID: XGTPKL
