| IPhone 14 Pro | |
| Manufacturer | Apple |
| Code name | |
| Release date | 2022-09-22 |
| Device type | Phone |
| How To Fix an iPhone 14 Pro That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
iPhone 14 Pro and Pro Max share the same top board, with only 1 resistor being different. This image shows where the Board ID resistor is located & what value it must be so it can be use for both iPhone 14 Pro and iPhone 14 Pro Max. iPhone 14 Pro: 1M Ohm. 14 Pro Max: 1K Ohm
iPhone 14 Pro Self Repair Store
Repair Manual ID: CBLXRW
