| IPhone 13 Pro Max | |
| Manufacturer | Apple |
| Code name | |
| Release date | |
| Device type | Phone |
| How To Fix an iPhone 13 That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
| How To Fix iPhone 13 Pro No Power or No IMEI After Backglass Repair | Main Logic Board | Soldering | 4. Specialist |
| IPhone 13 Pro and 13 Pro Max No Image Black Screen | Motherboard Screen | Soldering | 3. Hard |
iPhone 13 Pro Max Charging port Diode measurements using T824 USB-C / LIGHTNING PORT TAIL INSERTION TESTER. Image provided by A1 Phone Repairs
Diode readings for iPhone 13 Pro Max 5G antenna flex.
iPhone 13 Pro Max Self Repair Store
Repair Manual ID: EGKCZN
