| How To Fix iPhone 13 Pro No Power or No IMEI After Backglass Repair | |
| Device | iPhone 13 Pro, iPhone 13 Pro Max |
| Needs equipment | Hot Air Station, Soldering Iron, Replacement Chip, iPhone Board Preheater, Reballing Stencil, Middle Layer Reballing Stencils |
After back-glass replacement, the device may show:
- No IMEI
- No modem firmware
- No cellular service
- Device completely dead (no power)
This increasingly common failure happens when shops use back-glass cracking tool on the baseband zone of the sandwich logic board.
- “No IMEI” in Settings > General > About
- “Modem Firmware: N/A”
- High current jump on DCPS
- If the device has been restored with baseband issues, you will have to restore it again after fixing the baseband issue
- If the phone is not wiped, do not restore it. Only perform an update. Restoring may result in the device getting stuck on the Hello/activation screen
Full dead device
iPhone 13 Pro/Max BB_PMU Location on BoardView
1. Visual Inspection
- Inspect lower board under microscope
- Look for:
- Hairline cracks on BB_PMU
- Dent in the board from the backglass punch tool
(This is extremely common on iPhone 13 Pro / 14 Pro and Pro Max due to PMU location being very close to the back glass.)
2. Software Diagnostics
If phone still powers on:
- *#06# → No IMEI
- Settings → Modem Firmware = N/A
3. DC Power Supply Test
- Connect lower board only
- Press power:
- High Boot Current jump -> Short
4. Short Check
- Check around BB_PMU for shorts
1. Split the Logic Board (Sandwich Board Separation)
- Preheat to ~160–180°C
- Insert thin blades to separate upper & lower board
2. Remove the Cracked BB_PMU
- Clean Underfill around BB_PMU (Be careful of components around BB_PMU)
- Apply flux
- Carefully lift BB_PMU
- Inspect for damaged pads
- Clean with wick + fresh solder
3. Prepare & Reball New BB_PMU
- Use correct stencil for the model
- Inspect ball alignment carefully under microscope
4. Install New BB_PMU
- Align orientation markers correctly
- Reflow until IC self-centers
- Allow cooldown
- Clean board and inspect joints
5. Reconnect Upper & Lower Boards
- Align contacts
- Inspect under microscope for proper seam contact
6. Final Testing
- Connect to DCPS → verify normal boot current
- Boot device:
- IMEI should appear
- “Modem Firmware” should show correct version
- Test cellular, Wi-Fi calling, and SIM detection
