| IPhone 13 Pro Max | |
| Manufacturer | Apple |
| Code name | |
| Release date | |
| Device type | Phone |
| How To Fix an iPhone 13 That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
| How To Fix iPhone 13 Pro No Power or No IMEI After Backglass Repair | Main Logic Board | Soldering | 4. Specialist |
| IPhone 13 Pro and 13 Pro Max No Image Black Screen | Motherboard Screen | Soldering | 3. Hard |
iPhone 13 Pro Max Charging port Diode measurements using T824 USB-C / LIGHTNING PORT TAIL INSERTION TESTER. Image provided by A1 Phone Repairs
iPhone 13 Pro Max Self Repair Store
Repair Manual ID: EGKCZN
