| IPhone 13 Pro | |
| Manufacturer | [[:Category:|]] |
| Code name | |
| Release date | |
| Device type | |
| How To Fix an iPhone 13 That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
| How To Fix iPhone 13 Pro No Power or No IMEI After Backglass Repair | Main Logic Board | Soldering | 4. Specialist |
| IPhone 13 Pro and 13 Pro Max No Image Black Screen | Motherboard Screen | Soldering | 3. Hard |
