IPhone 12 Pro Max
Revision as of 09:04, 9 February 2024 by VCCBoardRepairs (talk | contribs)
IPhone 12 Pro Max
Manufacturer Apple
Code name
Release date 2020-10-23
Device type Phone
How To Repair iPhone 12 Pro Max No AudioMain Logic BoardSoldering4. Specialist
How To Repair iPhone 12 Pro Max fake temperature warningMain Logic Board
Charging Port
Soldering3. Hard
How to Repair iPhone 12 Pro Max that does not detect battery and does not chargeMain Logic BoardSoldering4. Specialist
LiDar Sensor
3. Hard
IPhone 12 Pro Max No IMEI and missing Modem FirmwareMotherboardSoldering3. Hard
WiFi IC
4. Specialist
