IPhone 14 Plus
Revision as of 22:16, 26 January 2024 by ASRepairs (talk | contribs)
IPhone 14 Plus
Manufacturer Apple
Code name
Release date
Device type Phone
How To Fix an iPhone 14 That Randomly RestartsMain Logic BoardPart replacement1. Easy
How To Fix iPhone 14 Not Charging due to open i2c line at battery connectorMain Logic BoardSoldering3. Hard
How To Turn On iPhone 14 to 16 Plus lower layerLogic BoardSoldering4. Specialist
How to fix iPhone 14 Error 9 with failed RoseMain Logic BoardSoldering4. Specialist
WiFi IC
4. Specialist
