| IPhone 14 Plus | |
| Manufacturer | [[:Category:|]] |
| Code name | |
| Release date | |
| Device type | |
| How To Fix an iPhone 14 That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
| How To Turn On iPhone 14 to 16 Plus lower layer | Logic Board | Soldering | 4. Specialist |
