| How To Recover Original Sysconfig Data from iPhone | |
| Device | iPhone 6, iPhone 6S, iPhone 6S Plus, iPhone 7, iPhone 7 Plus, iPhone 8, iPhone 8 Plus, iPhone X, iPhone XS, iPhone XS Max, iPhone 11, iPhone 11 Pro, iPhone 11 Pro Max |
| Affects part(s) | Main Logic Board, NAND |
| Needs equipment | Hot Air Station, Soldering Iron, JCID Programmers, JCID Software |
Problem Description
When the original NAND of an iPhone is dead and replaced with a new chip, the device fails activation due to mismatch of serial number, Wi-Fi MAC address, and Bluetooth MAC address.
This issue occurs because SysConfig data stored on the original NAND is missing.
- Device flashes successfully but fails at activation screen.
- Serial number may appear as “XXXXXXXX” or a random serial number will appear.
- Wi-Fi and Bluetooth may not function or show random MAC addresses.
- iTunes / 3uTools may show “Activation Error” or “Could not activate iPhone.” (See Figure 1)
- Flash iPhone with new new NAND using 3uTools or iTunes.
- Observe that phone boots to setup screen but does not activate.
- Check Serial / Wi-Fi MAC / BT MAC — mismatch or missing.
- Confirm there is no baseband or logic board fault before proceeding (baseband/nfc issue can also cause activation failure).
- Remove Bad NAND: Desolder the original faulty NAND chip from the logic board.
- Install & Flash New NAND: Solder new NAND, flash using iTunes/3uTools, confirm device boots (activation will still fail).
- Remove New NAND: Desolder the new NAND from the board again.
- Read SysConfig:
- Launch JCID Software.
- Connect JC V1S Pro with respective NAND or JC P13/P15 Programmer module to PC.
Select programmer and click connect. - Insert NAND into programmer.
- Go to Programmer Interface → Query Info → Query Code/Unbind.
QueryCode/Unbind - JCID Repair Assistant - Wait (up to 30 mins) for software to retrieve original Serial, Wi-Fi MAC, BT MAC.
- Write SysConfig to NAND:
- Reinstall NAND: Solder NAND back onto logic board.
- Reflash Device: Perform clean flash with iTunes/3uTools to finalize.
- Verify Activation: Boot and confirm device activates normally and Wi-Fi/Bluetooth work.
