IPhone 12 Pro
Revision as of 09:02, 9 February 2024 by VCCBoardRepairs (talk | contribs) (iPhone 12 Pro Device Page)
IPhone 12 Pro
Manufacturer [[:Category:|]]
Code name
Release date
Device type
LiDar Sensor
3. Hard
WiFi IC
4. Specialist
