IPhone 12 Pro
Revision as of 15:22, 12 November 2025 by IamMyron07 (talk | contribs) (→‎Device pictures)
IPhone 12 Pro
Manufacturer Apple
Code name
Release date 2020-10-23
Device type Phone
LiDar Sensor
3. Hard
WiFi IC
4. Specialist
iPhone 12 Pro Self Repair Store
Repair Manual ID: FWRUJK
Schematics for iPhone 12 Pro: https://www.sendspace.com/file/zaxilx
