AMD Polaris (RX 400/500) GPU Diagnosing Guide
Revision as of 20:27, 7 November 2023 by ASRepairs (talk | contribs)
This guide is applicable to most Polaris cards ranging from the 460 to the 590 series. While some vendors may produce different PCBs or utilize distinct components, the general operational principles for these cards are typically consistent unless otherwise specified. This guide uses a reference RX 480 as an example.
Type
Device(s)
Difficulty
The Card Layout
RX480 reference board front view (Figure 1)
RX480 reference board back view (Figure 2)
PCB Image courtesy of TechPowerUp
Before proceeding, it's advisable to inspect the card for physical damage, especially in the case of cards without a backplate. They can easily lose some components on the back due to poor handling.
12V Rails
Begin by measuring the resistances of the 12V rail originating from the PCIe slot (first 3 pins, see Figure 1).
Subsequently, measure each inductor for external power connectors (some higher end cards have multiple external power connectors, and each of them has its own inductor, so measure each one individually).
The resistance value may vary from card to card, but it should generally be in the thousands+ Ω range. If you measure 50Ω or less, you likely have a short on the card.
Solution: Refer to this page dedicated to Base Voltage Rail Short on Polaris GPUs.
3.3V Rail
The card derives 3.3V power solely from the PCIe slot. It is obtained from the 4th pin going left from the PCIe key notch in the front and the 2nd and 3rd pins on the back going from the notch again (as depicted in Figures 1 and 2).
If you measure less than 50Ω on one or multiple base rails, you likely have a card with a short. In such cases, the computer may not turn on because the power supply activates overcurrent protection (OCP).
Solution: Check out this page dedicated to Base Voltage Rail Short on Polaris GPUs.
**On MSI RX cards, the 3.3V pin typically has a resistance to ground of about 200 ohms.
If there is no short, you can continue with the troubleshooting.
Step 2: Minor Voltage Rails (5V, 1.8V, Display Rail, VMem, VCore, and VDDCI)
Check the resistance of the output of these rails and compare them with Figures 1 and 2. VCore has such low resistance that measuring its resistance may not be very useful. A more helpful approach is to measure its resistance against the 12V rails, not GND.
Step 3: Powering On the Card
Power Sequence
In most Polaris GPUs, they typically activate in the following order:
5V → 1.8V → Display Rail → VMem/VDDCI → VCore (In some cases, VDDCI may activate after VMem, while in other cases, VDDCI and VCore are controlled by the same controller and activate simultaneously.)
For example, if the 5V rail doesn't activate, nothing else in the chain will activate either, which means no fan spin if there's an issue with 5V or 1.8V.
If you're missing one of them, refer to their respective pages for more details on how they work and potential issues:
Step 4: No Video Output
Memory Problems
BIOS Problems
If the memory is fine or the card isn't even detected in Linux, the issue is likely related to the BIOS. Check out the BIOS Problems on Polaris GPUs page for guidance.
Crystal Oscillator
Crystal oscillators, often marked with "Y" followed by a number, can occasionally fail, resulting in the card not booting up. In most Polaris GPUs, the oscillator frequency is 27MHz. To test it, you'll need an oscilloscope or a multimeter with an Hz function that can exceed 27MHz.
PERSTB Signal
PERSTb signal schematic view. (Figure 3)
Start by checking all inputs, if one is missing trace it according to the schematic in figure 3 and replace the faulty components. If all the inputs are present but the output is low, check the Vcc pin and make sure the gate is powered, after that, replace it if all inputs and power is present on the gate.
Step 5: GPU outputs a picture
Artifacting
Error 43
Start by making sure the memory is fine as shown in the guide above, then check if the BIOS is not corrupted/modded (flash original bios from either TPU BIOS Library or manufacturer's site) and check the bios circuit as shown here: BIOS Problems on Polaris GPUs.
