IPhone 11
IPhone 11
Manufacturer Apple
Code name
Release date 2019-09-20
Device type Phone
How To Fix an iPhone 11 That Randomly RestartsMain Logic BoardPart replacement1. Easy
NAND
Soldering4. Specialist
How To Repair an iPhone 11 that is bootloopingMain Logic BoardSoldering3. Hard
How to fix iPhone 11 stuck in recovery mode with failed at Rose Error -1Main Logic BoardSoldering4. Specialist
How to repair iPhone 11 Dead Not ChargingLogic Board
CPU
IPhone 11 Always Searching for Network IMEI PresentMotherboardSoldering3. Hard
IPhone 11 No Cellular Service, No IMEI PresentMotherboardSoldering3. Hard
IPhone 11 Not Powering on, 2A or Higher Power Draw After Prompt to BootMotherboardSoldering3. Hard
IPhone 11 Not Powering on, After Prompt to Boot Current Jumps Back and Forth From 0 A to 320 mA, Then 0 A to 1.4 A, Then 0 A to 500 mA, and so onMain Logic BoardSoldering3. Hard
IPhone 11 with half backlight on displayMotherboardSoldering3. Hard
