IPhone 12
Revision as of 06:13, 20 May 2025 by VCCBoardRepairs (talk | contribs) (Corrected iPhone 12 reference measurement format)
IPhone 12
Manufacturer Apple
Code name A2172, A2402, A2403, A2404
Release date 2020-10-23
Device type Phone
WiFi IC
4. Specialist
iPhone 12 Self Repair Store
Repair Manual ID: RBQEVH
