| IPhone 12 | |
| Manufacturer | Apple |
| Code name | A2172, A2402, A2403, A2404 |
| Release date | 2020-10-23 |
| Device type | Phone |
| How To Fix an iPhone 12 Pro that is not charging and touch not working | Main Logic Board | Soldering | 4. Specialist |
| How To Fix an iPhone 12 That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
| IPhone 12 Screen Stays Dim and Can't Increase Brightness Repair | Motherboard | Part replacement | 1. Easy |
| IPhone 12 Stuck In Recovery Mode After Water Damage Solution | Main Logic Board | Soldering | 3. Hard |
| IPhone 12 Stuck on the Apple Logo Error 4013 Repair | Motherboard | Part replacement | 1. Easy |
iPhone 12 Self Repair Store
Repair Manual ID: RBQEVH
