IPhone 15 Pro
Revision as of 01:12, 4 April 2025 by VCCBoardRepairs (talk | contribs) (Added iPhone 15 Pro - USB Port Readings through Mechanic T-824 Reader)
IPhone 15 Pro
Manufacturer Apple
Code name D83 Vantage
Release date Friday, September 22
Device type Phone
How To Fix an iPhone 15 Pro That Randomly RestartsMain Logic BoardPart replacement1. Easy
How To Repair an iPhone 15 Pro Max Error 9 Caused Due To Aftermarket BackGlassLogic Board
BackGlass/Wireless Charging Flex
2. Medium
How to fix an iPhone 15 Pro Pro Max camera which is not focusingMain Logic Board4. Specialist
WiFi IC
4. Specialist
IPhone 15 Pro Max Dead and Not ChargingMain Logic BoardSoldering4. Specialist
IPhone 15 Pro Stuck at 1 Percent Charging and No Battery Data 0xa1 Panic Log CodeSoldering
BGA
4. Specialist
IPhone 15 Series - No Touch/No ChargingMain Logic BoardSoldering3. Hard
Apple Self Service iPhone 15 Pro
Repair Manual ID: VRGJFQ
