| IPhone 15 Plus | |
| Manufacturer | Apple |
| Code name | A3094, A2847, A3093, A3096 |
| Release date | 2023-09-22 |
| Device type | Phone |
| How To Fix an iPhone 15 That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
| How To Fix an iPhone 15 With Touch Not Working | Logic Board | Soldering | 4. Specialist |
| How To Turn On iPhone 14 to 16 Plus lower layer | Logic Board | Soldering | 4. Specialist |
| IPhone 15 Series - No Touch/No Charging | Main Logic Board | Soldering | 3. Hard |
iPhone 15 Plus Board ID is 1K Ohm for R0812
