| IPhone 13 | |
| Manufacturer | Apple |
| Code name | |
| Release date | |
| Device type | Phone |
| How To Fix An iPhone 13 with No Audio No Vibration and Slow Camera Response | Main Logic Board | Soldering | 4. Specialist |
| How To Fix an iPhone 13 Rear Camera Not Focusing After A Drop | Motherboard Camera | Soldering | 4. Specialist |
| How To Fix an iPhone 13 That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
