IPhone 12
Revision as of 22:11, 19 January 2024 by KevinShort (talk | contribs)
IPhone 12
Manufacturer Apple
Code name A2172, A2402, A2403, A2404
Release date 2020-10-23
Device type Phone
WiFi IC
4. Specialist
