IPhone 12
Revision as of 21:59, 19 January 2024 by KevinShort (talk | contribs) (Created page with "{{stub}} {{Device page }} ==Guides== {{List Guides}} ==Device pictures== <gallery showthumbnails="1"> File:Example device pictures.jpg </gallery> ==PCB pictures== <gallery showthumbnails="1"> File:Example pcb pictures.jpg </gallery> ==Reference measurements (also schematics if available)== <gallery showthumbnails="1"> File:Example measurement pictures.jpg </gallery> ==More Information/External Sources== You can manually link to external sources for additional inform...")
IPhone 12
Manufacturer [[:Category:|]]
Code name
Release date
Device type
WiFi IC
4. Specialist
