| IPhone 15 | |
| Manufacturer | Apple |
| Code name | A3090, A2846, A3089, A3092 |
| Release date | 2023-09-22 |
| Device type | Phone |
| How To Fix an iPhone 15 That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
| How To Fix an iPhone 15 With Touch Not Working | Logic Board | Soldering | 4. Specialist |
| How To Turn On iPhone 14 to 16 Plus lower layer | Logic Board | Soldering | 4. Specialist |
| How to Fix iPhone 15 Rear Camera Not Switching Lenses Intermittent Camera | Main Logicboard | Soldering | 3. Hard |
| IPhone 15 Series - No Touch/No Charging | Main Logic Board | Soldering | 3. Hard |
iPhone 15 Board ID is 1M Ohm for R0812
iPhone 15 Mechanic USB-C readings
iPhone 15 Self Service Repair Manual ID: QNCHKL
