IPhone 15 Plus
Revision as of 15:32, 12 November 2025 by IamMyron07 (talk | contribs) (→‎Device pictures)
IPhone 15 Plus
Manufacturer Apple
Code name A3094, A2847, A3093, A3096
Release date 2023-09-22
Device type Phone
How To Fix an iPhone 15 That Randomly RestartsMain Logic BoardPart replacement1. Easy
How To Fix an iPhone 15 With Touch Not WorkingLogic BoardSoldering4. Specialist
How To Turn On iPhone 14 to 16 Plus lower layerLogic BoardSoldering4. Specialist
WiFi IC
4. Specialist
IPhone 15 Series - No Touch/No ChargingMain Logic BoardSoldering3. Hard
iPhone 15 Plus Known Good Mechanic USB C Readings
