IPhone 12 Mini
Revision as of 20:29, 30 June 2025 by Tiago199988 (talk | contribs) (Added device pictures)
IPhone 12 Mini
Manufacturer Apple
Code name
Release date 2020-10-23
Device type Phone
WiFi IC
4. Specialist
iPhone 12 Mini Self Repair Store
Repair Manual ID: VXUZTC
