| PlayStation 5 | |
| Manufacturer | Sony |
| Code name | Erebus |
| Release date | November 11, 2020 |
The PlayStation 5 (commonly referred to as PS5) is a home video game console developed by Sony. It is competing with Microsoft's Xbox Series X and S with the ninth generation of consoles.
| PS5 Standby Boot Sequence & Consumption Analysis | Troubleshooting/Diagnostics | 2. Medium |
| PlayStation 5 EMC Errlogs | Troubleshooting/Diagnostics |
| How To Repair PS5 Controller Not Working in Normal Mode but Works in Safe Mode | Main Logic Board | Soldering | 4. Specialist |
| PlayStation 5 3 beeps when power is plugged in | Motherboard | Soldering | 2. Medium |
| PlayStation 5 Disk to Digital Conversion | Motherboard Disk Drive | Soldering | 3. Hard |
| PlayStation 5 Fan not working | Motherboard | 2. Medium | |
| PlayStation 5 Fault Finding Using UART | Motherboard | 2. Medium | |
| PlayStation 5 No Image and No Sound | Motherboard | Soldering | 3. Hard |
| PlayStation 5 Not turning on repair | Motherboard | Soldering | 3. Hard |
| PlayStation 5 Overheating and Shutting down | Console | 1. Easy | |
| PlayStation 5 Single beep from power button every 30 seconds repair | Motherboard | Soldering | 3. Hard |
PS5 Screw Lengths, locations, and quantities.
EDM-010
EDM-010
PS5 HDMI Port Diode Mode Readings through Mechanic T-824 Tester
PS5 HDMI Diode Measurements of board without port installed. Used Fluke 115 multimeter - Red probe on ground black probe on respective pads..
PS5 USB 3.0 Diode Measurements
PS5 Power and Disk FPC Diode Measurements
PS5 M2 SSD FPC Diode Measurements
PS5 LED FPC Diode Measurements
PS5 Front USB Diode Measurements
PS5 LAN Port Diode Measurements
PS5 Disk Drive Data FPC Diode Measurements
PS5 FAN and Disk drive power Diode Measurements
Bios image Dumps [1]
